2011 Air Filter
as someone said before... its the most secured air filter EVER
its held down by some rubber grommets yank on the thing until they pop out of the holes..or try using some wd40 to loosen/lube the rubber..after that its like 10 secrews or something like that holding the casing together
check this thread out for more info
https://www.chevyhhr.net/forums/show...ghlight=filter
