60k Extended warranty About to expire: what could need fixed?
Old 03-04-2011 | 05:47 PM
mgeinitz's Avatar
I have 2k till 60k warranty runs out on my 2006 HHT 2LT 2.4. I am going to pay the dealer to look over everything. What types of things might they find. Or does anyone know of parts or items I should tell them to pay attention too?
Thanks guys you never let me down.
Old 03-04-2011 | 10:55 PM
nacademus's Avatar
Belt, brakes, pay attention to brake fluid color (maybe flush it), control arm bushings/sway bar end links and bushings, tie-rod ends for play, wheel bearings, thermostat, intermediate shaft play, cabin air filter, idk... EVERYTHING! lol
Old 03-05-2011 | 10:21 PM
Also look for leaky struts & rear shocks. Worth checking..
If you have any quirks that you are aware of..
Check all lights/ run, brake & turn. Hi/Low beams. (this you can do to point it out for repair)..
Old 03-06-2011 | 01:43 AM
TiggersHHR's Avatar
I second nacademus list. Most important is check the front suspension - sway bar links and lower control arm bushings especially. If any of your struts or shocks are bad, under warranty GM will only replace the strut or shock that is bad - they will not replace both sides just because one is bad. If you want new shocks or struts I would look other place - might find them less expensive. Make sure they check both half shafts, all of the cv joints, and cv boots for cracks/tears.
skyline26
Maintenance and Upkeep
02-19-2014 11:49 AM
remharri
07-29-2011 10:32 PM
saltyfishguy
04-25-2008 01:25 PM
andoll83
01-03-2008 10:07 PM
Goose
06-22-2007 01:24 AM
Quick Reply: 60k Extended warranty About to expire: what could need fixed?
