another oil change question
Old 07-14-2012, 01:49 PM
Budster's Avatar
OK, I’ve decided that it would be economical for me to change my own oil. First problem is what engine do I have 2.2 or 2.4, how do I determine that?
Does it make a difference when buying the filter?
2006 HHR LT(2?) how do I know if I have a LT2? (I am 2nd owner)
Auto trans
Leather heated seats
Single CD radio
Running boards
17” wheels
TIA
Jerry
Budster is offline
Old 07-14-2012, 01:58 PM
Jgooden93's Avatar
Somewhere under the hood on a emmisions tag should tell you 2.2 or 2.4 probably the easiest way to tell
Jgooden93 is offline
Old 07-14-2012, 02:50 PM
2007HHRLT's Avatar
You should have a LT2 with the 2.4L. You can always check the Vin or just look for LE5 in the glove box RPO sticker.
2007HHRLT is offline
Old 07-14-2012, 03:00 PM
badassbowtie's Avatar
my old 07 2lt was a 2.4. it shouldn't matter though as both engines are 5W30 and conventional oil. unless it was switched to synthetic
badassbowtie is offline
Old 07-14-2012, 05:58 PM
Originally Posted by budster
ok, i’ve decided that it would be economical for me to change my own oil. First problem is what engine do i have 2.2 or 2.4, how do i determine that?
Tia
jerry
NO!
Does not matter conventional or synthetic or blend or any mixture thereof!!!!!!! 5W30 5 Qts. Buy whatever brand or "quality" that you prefer, nothing bad will happen. Change it when your Grandfather said you should.
RTFM, it's available.
Maybe I should just say "shop around and get the most expensive oil and filter that you can find, and change it every 500 miles, just totally disregard the oil life monitor on the DIC, because GM is trying to kill you and the engine with their recommendations." OR, just read the "Owner Manual", you could save some angst.
And, I notice that you have been a member here since January 2011. Who has been changing the oil & filter, and why do you not know with what products?
Sorry for the sarcasm, but this is really old news and easily searched! And really does not make any difference, you go to the autoparts store and say "here is my make/model/VIN give me the most expensive parts that you can".
donbrew is offline
Old 07-14-2012, 06:23 PM
Budster's Avatar
what weight should I use with synthetic?
Thanks to everyone for the quick replies!
Jerry
Budster is offline
Old 07-14-2012, 06:25 PM
Budster's Avatar
Originally Posted by donbrew
NO!
I did try the search and found nothing about the weights and other 'oil' related topics, old guy here and am probably not using the search correctly, sorry......
Jerry
Budster is offline
Old 07-14-2012, 06:44 PM
solman98's Avatar
Jerry
YOu use the same with either regular or synethic. 5W30
solman98 is offline
Old 07-14-2012, 07:20 PM
jay loukakis's Avatar
Wheres Whopper when we need him.
jay loukakis is offline
Old 07-14-2012, 08:25 PM
The owners manual has all the info you need on oil and service.
If you don't have an owners manual, one is available "FREE" on this site for you to download.
firemangeorge is online now
Quick Reply: another oil change question
