best oil filter to buy
Really it’s your preference, I prefer Fram , or AC Delco. Others might suggest K&N or Wix, maybe Mobil .
the BlackSwan isn’t an SS but I do install either Fram for synthetic oil Ultra Synthetic XG 9018 or AC Delco PF457G
My daughter took her Cruze in for a CEL - turns out it was the valve cover gasket. The mechanic noticed a serious amount of sludge and said even though she changes the oil regularly, the mechanic stressed with GM small engines you need to change the oil a lot more often than recommended by GM and a quality filter is a must. With that in mind, I went ahead and ordered the AC Delco PF458G which includes the filter, cap and o-ring (as recommended by Firemangeorge) from RockAuto. It’s only a few dollars more and worth the piece of mind and I think I’ll go to a 3,000 mile schedule.
3,000 is a little to often, considering synthetic oil will last 10,000 miles, I stick to a schedule of every 6 months.
the first of April , then the first of October. This way I have fresh oil for our trip to Florida and then Cape Cod.
and it works out to approximately 5,000 miles . Time to check and clean the brakes , inspect the suspension, change tires.
There's lots of information and even more opinions at this forum:
Bob's The Oil Guy - Oil Filter Forum
I use Mobile 1 Synthetic Oil and Filter every 5k miles ! WIX Napa Gold or AC Delco usually, I do every 5k in my Truck and Motorcycles as well !
That Bob the Oil guy link is a good video :) Thanks Moonwink
Like on our own site! It’s been discussed many times
https://www.google.ca/search?q=HHR+b...&bih=796&dpr=2
