Brakes??
Old 04-03-2011 | 07:23 AM
jjdurrant's Avatar
Brakes??
Hey guys. I have an 07 LT with 65k miles. I am getting steering wheel shake\wobble when I apply brake and loud roud noise at around 40mph. I am thinking tire rotation and brakes are needed. Tires Plus did the pads and rotors once. But that was about 25-30k miles ago. Thoughts?
Old 04-03-2011 | 07:50 AM
LawDog88's Avatar
could be time for it, yes.
Old 04-03-2011 | 07:56 AM
hyperv6's Avatar
If they are making noise I would guess the Brakes are worn out. Milesw you get depend on how you drive. 30K-60k is normal.
Seeing you worn out the first set at 30K I would think by 60K you are due again.
Old 04-03-2011 | 08:06 AM
jjdurrant's Avatar
Thx guys. I am going to inspect everything today. I plan to do the brakes myself. First time! Any tips?
Old 04-03-2011 | 08:51 AM
jjdurrant's Avatar
I am confused now.. the brakes and rotors look fine.. see pics. Other ideas?
Old 04-03-2011 | 09:29 AM
1970judge's Avatar
Uh, "wobble/shake" is most likely rotor warp. Your not going to see it.
Old 04-03-2011 | 09:52 AM
jjdurrant's Avatar
I am going to have rotors turned and all four balanced and rotated. Will let ya guys know.
Old 04-03-2011 | 10:19 AM
hyperv6's Avatar
It could be rotor thickness variation. The can wear uneven if the hub bearings get out .002. GM has a tab on this. It often shows up at 60k plus miles. Cutting the rotor will only fix it short term.
A lot of people like to blame things on a warped rotor when often it can be RTV or even embedded brake material in the rotor surface. A clean up cut will fix either but you need to bed the brakes in and check the bearing play or it will return.
The noise issue is what puzzles me. What kind of noise? If the noise is when the the brakes are off you could have a bad bearing and the related RTV. Cutting the rotors will work shor term and either the bearing will fail or you will get the pulse back.
Todays bearings are ball bearings for better MPG. They are not as good as a roller but they have less resistance. They are an issue on most new cars of all makes. The days where the old roller bearing lasting 200,000 miles are long gone.
The look in the photos is hard to tell but I do see a little glazing on the surface and that can cause the pulse too but seldom noise.
Old 04-03-2011 | 05:29 PM
jjdurrant's Avatar
new pads and rotors resolved the wheel shake and petal pulsation.. but I am still getting some noise.. wheels bearings known to go out this early?
Old 04-03-2011 | 05:31 PM
At 65k bearing failure can crop up, I'd investigate that as your next step if you've eliminated all other possibilities.
Quick Reply: Brakes??
