Can't pinpoint what sounds like a bearing issue!
Hey guys, longtime member but absent for years.
I have an issue. 2008 HHR LS. I have had a "mud tire" noise over the past year that has gotten progressively worse. It sounds JUST LIKE a bad bearing. I'm usually very good at pinpointing which one is bad. It would sound worse on fast left swerve, go quiet on right swerves. Must be passenger side, definitely front. Had new bearing put on few months ago, no change. Noise much worse now. Recently bought new set of tires, figured maybe the old shop accidentally put new bearing on driver side, so I bought a new bearing for the tire shop to slap on, still no change. This is driving me NUTS! I really don't think there's a chance in hell that it's the driver side bearing. Is there any way possible that a CV shaft could make a similar noise? Tire shop says no. Should I replace CV shaft first or go right to new bearing on driver side? Thanks guys!
I’m thinking the driver side bearing is failing, make sure they don’t use an air impact gun on the axle nut, and that they torque the bearing bolts correctly 85 ft lbs for the 3 mounting bolts and 155 ft lbs for the axle nut. A new one should be used not the old one.
CV axles usually click when turning as the start to fail.
I always recommend replacing both hub bearings at the same time as they like to fail in pairs.
but that’s just me.
but that’s just me.
but that’s just me.
but that’s just me.
I've been super paranoid that it's a bearing in the transmission that the CV shaft connects to.
Axles are fairly cheap, why worry about the transmission? I have only heard of one output bearing being replaced.
Labor to replace both is 1.6 hours (includes 15 minutes to get it on a lift and remove the tires), the last rebuilt axles I got were about $60 each. Easy to do in the driveway.
