Do you change oil according to the oil life monitor?
Old 02-02-2010 | 08:54 PM
Jim's 2009's Avatar
I haven't so far, I have just been changing it every 5-6000 miles but in the cold I have let it go to 7500 miles and it's only at 41%. Do you let your's go to 0% or go by the miles driven? I do us a semi synthetic oil. Not sure if that should last longer or not.
Old 02-02-2010 | 09:11 PM
eagle914's Avatar
I had 63000 miles on my old 06 2LT and would change when the sensor said to do it. No problems. I used Mobil 1 synthetic 5/20 or 5/30 I can't remember which.
Old 02-02-2010 | 09:19 PM
Jim's 2009's Avatar
Think I will at least wait until it's a little warmer.
Old 02-02-2010 | 09:46 PM
ecl's Avatar
ecl
I change mine when it hits 10-15%ish wich is normally around 6k miles and I use mobil one full synthetic
Old 02-02-2010 | 09:49 PM
dpoll995's Avatar
i change mine at about 10% to 5% which runs about 8 to 9k. i get it done at the dealer with mobil1 syn. oil.
Old 02-02-2010 | 10:29 PM
IgottaWoody's Avatar
My 3rd ol change coming up and I have just under 26k miles..anywheres between 5 and 20%......gives you wiggle room to 'plan' it. Right now I'm at 12 %
Old 02-03-2010 | 01:02 AM
Dealer had just changed it before I bought mine. (which was of course overfull some)...
So I changed it to M1 full syn 5-30 shortly after I got it. I'm gonna go by the OLM, but never more than 1 year between changes..
Old 02-03-2010 | 06:00 AM
solman98's Avatar
I pick up the suppies when it hits 10% and then do it when I have time.
Old 02-03-2010 | 03:23 PM
Jim's 2009's Avatar
Can't believe at 7500 miles and I am still at 41%. It IS all highway miles.
Old 02-03-2010 | 08:05 PM
Cajun's Avatar
I use 15,000 mile synthetic....and change at 10,000 mile intervals.
Quick Reply: Do you change oil according to the oil life monitor?
