Dumb question about oil filter
Old 12-01-2010, 06:13 PM
Ok. A simple question. When replacing the oil filter do you folks :
(1) Put new oil filter in, then replace cap, or
(2) Put new oil filter in cap and replace togeather ?
Reason for the question is because we're dealing with 2 seperate O-rings: big one on cap, small one on filter. Do you think it matters which way you replace the filter? Just curious.
firemangeorge is offline
Old 12-01-2010, 06:18 PM
THE BATMAN's Avatar
I put the filter in then replace the cap , seems like the best way to do it.
THE BATMAN is offline
Old 12-01-2010, 07:49 PM
Snoopy's Avatar
I would think inserting the filter into the cap first, would be the smart way. It would assure proper alignment of everything (also was told this is correct by GM Engineering).
I SUSPECT some of the semi crushed filter that owners have experienced, may have come from installing the filter....then screwing on the cap. Just a suspicion, however.
Snoopy is offline
Old 12-01-2010, 07:59 PM
HipHotRod's Avatar
Yep - insert in cap 1st.
HipHotRod is offline
Old 12-01-2010, 08:36 PM
Lucky's Avatar
cap first
Lucky is offline
Old 12-01-2010, 09:20 PM
Ditto...... I suspect snoopy is right on the crushed filters. If the filter is placed into the engine first and the fitted ring/cup in the cap doesn't line up right it will smash the filter some before it "pops" into place in the cap. Especially if you have the car up on ramps or stands as the filter will lean back some and not be centered when you go to put the cap on.
Greybeard999 is offline
Old 12-01-2010, 09:27 PM
ChevyMgr's Avatar
Cap first works well.
ChevyMgr is offline
Old 12-01-2010, 11:12 PM
Agreed, & I would only add, imo helps on the o-rings to wipe em with oil before install, so they don't chafe, & are lubed to slide in easily..
sleeper is offline
Old 12-01-2010, 11:28 PM
djr1973's Avatar
I always put the filter into the cap then screw the cap in,I have 2 GM products w/2.4l, my HHR and wifes G6.
djr1973 is offline
Old 12-02-2010, 05:28 AM
solman98's Avatar
The filter is designed to snap onto the cap before installation.
solman98 is offline
Quick Reply: Dumb question about oil filter
