Engine Tune Up Questions
#31
If the leak is a broken flex pipe, you may have a bad motor mount, in case no one mentioned that yet.
#32
No. But an abnormally load exhaust is a leak. If the leak is upstream of the O2 sensor, the computer can draw faulty conclusions about the a/f mixture. All leaks in the exhaust system are hazardous and should be fixed, but leaks upstream of the O2 sensor will cause engine problems, too.
