Fine scratches
Old 08-13-2013 | 05:45 PM
Fox Hat's Avatar
For those that have some time to watch a few educational videos regarding car care and see some cool vehicles have a look. WARNING You WILL learn and not notice how much time has transpired!!
YOU HAVE BEEN WARNED!!!
http://slashdrive.tv/tagged/drive_clean
Old 08-14-2013 | 10:58 AM
jaymz's Avatar
You can get a buffer at HArbor Freight for about $50.
Meguiars #101
Megs Ultimate Compound
Megs Ultimate Polish
Blackfire Wet Diamond
Orange, white and red buffer pads (Lake Country).
Jim
Old 08-14-2013 | 03:52 PM
hyperv6's Avatar
I would caution on getting a buffer at Harbor unless you know how to use one. Many may want to stick to a orbital if they have not used a regular buffer much. It is something you need to learn with experience and practice. Also on a old car that if you burn through you are not mad or out a repaint.
Also if you use your tools a lot spend the extra money to get a good 6" Porter Cable. The bearings will not go out in it as like many of the cheaper ones.
Old 08-14-2013 | 04:00 PM
jaymz's Avatar
The item I recommended IS a D/A buffer; you have to be a true moron to mess up with a buffer. It's the hi speed orbital that is easy to burn thru the paint. The Harbor Freight model has gotten some pretty decent reviews. If you want to go for a good one, the Griots Garage is better than the Porter Cable.
Jim
Old 08-15-2013 | 05:55 AM
hyperv6's Avatar
Jim
Are you confusing what an Variable Speed Orbital buffer is vs. a rotary buffer?
It does not take a moron to burn through with a rotary buffer. I see it all the time. It is generally someone who has little experience and they get on a edge of corner and burn through easily as it does not have the random orbital motion and can spin at very high speed. This is the one most body shops use to do heavy cutting.
An orbital is much like a DA but generally 6.5 inches and Is made for more for polishing vs heavy cutting buffing with the random motion and variable speed even the least experienced person will not buff through. To burn through you have to pretty well have very thin paint or really work an area to death to do any harm. This is the one most shops and detailers use for finishing work.
Porter Cable, Griots and Meguires are all pretty much the same. At one time Porter made them for one of them. Generally you can get a better buy on the Porter that is most common one you see detailers use. It has a much stronger Roller Bearing set up.
The buffers from Harbor are like most other cheap ones. They are good for the home user or occational user. I have the cheap hand held small grinders from there. I wear it or I toss it because I do not use it often. My Orbital gets a lot of work so I spent the extra money and after 5 years of heavy work it is running fine.
Old 08-15-2013 | 07:33 AM
DaytonaBlueMetallic's Avatar
It is not the product line but the type of product you use as to how gentle.
I have Meguires products that will finely polish to those that will hone though the paint easily.
The key is the selection of product and using the proper grade of product you need for a proper finish.
Also there are a lot of product like Nu-Finish and others that are a one step that really do not repair the finish but mask the flaws. There are many high silicone products that mask only and they do a good job as long as you do not want a long term proper fix.
The key is education of how to properly polish and repair paint is what one needs to do this right. Also important are what are your standards. My standards are as good or better than new. Most do not go that far but that is just me.
The thing is if you do step up your standards and education on what products to use and how to use them properly you will not only have a better looking car but you will also get top value at resale. I have always been able to move my used cars fast and in many cases in hours of putting them up for sale.
The info on many web sites can get jumbled up as with different standards and opinions the true technical knowledge gets lost.
Adams and Meguires both have good information on how to deal and prepare with paint and damage. Also once you learn this it is a easy way to pick up $150 or more for a Saturdays afternoons work.
I'm in complete agreement here. Like he said, depends on how much of a fanatic you are (I go beyond anal)
Old 08-15-2013 | 08:26 AM
postalboy's Avatar
I don't want to take a chance on burning my paint. I don't intend to need to use a buffer often but I do want something that I can turn down to a low speed and is orbital. Porter Cable seems to be the way to go. I'll watch all the videos I can, get the proper pads' polishes, ect and go afer my scratches. Thanks for all the advice.
Old 08-15-2013 | 08:45 AM
Postalboy,
In general I would strongly recommend against purchasing anything from Harbor Freight... Nothing there has too good of a reputation.
I'll admit, I ignored their reputation and bought a motorcycle lift from them. It nearly destroyed my bike.
Never again....
Old 08-15-2013 | 08:55 AM
jaymz's Avatar
I think we have a difference in terminology. I defer to your use of orbital buffer. In my book, an orbital and a D/A buffer (dual action) are the same thing. And your really DO have to be a moron to mess up your paint with one. I prefer the Griots because it is the most powerful unit out there.
Jim
Old 08-15-2013 | 05:04 PM
hyperv6's Avatar
Jim
Generally Orbital or Duel Orbital are the same but you said an Orbital would do damage.
I think it was just a typo so we are on the same page.
Griots is a good unit but the power difference really has never been an issue with me. The key to me is if you use it a lot get the unit with the best bearings as they take a beating with the orbiting action. Cheap units tend to fail if you use them much.
There are reasons why Harbor Freight units come with extra brushes. LOL!
My rotary buffer is a soft start unit but it is also not a top line as I do not use it much for detailing unless I have a really bad paint job to deal with. I also use it when working on new fresh paint to cut it down to a workable surface. Ruff it in so to speak.
ultramicrofiber
Maintenance and Upkeep
65
03-25-2013 12:15 AM
xonelife1983x
2.0L Performance Tech
7
05-01-2010 11:55 PM
RocketBuSS
27
02-15-2009 01:56 PM
pea420
2.4L Performance Tech
11
10-16-2007 09:36 PM
Firewatcher
06-21-2006 02:10 PM
Quick Reply: Fine scratches
