Free Oil Change FTW!
Does the oil change message have to be on? What are there rules as to how often the service can be performed? Does it include tire rotations? Is it from GMPP? Didn't the debate suck last night? Oops, got carried away.
100% free 5 times a year.
my free oil changes where included in the deal i made......free oil changes for 3 years.......i paid nothing.........noda...........Zelch....zero.....
every 3000 go in get oil,filter, and all the fluids, check air.. wear.....etc... and a check off sheet..
If your dealer indicated they lubed the chassis, I would be highly suspect to the rest of the services they SAID they performed.
Sounds to me like it's an "automatic....check the sheet" kind of thing.
Mentioning that.....were you supplied a service sheet listing all these services? When my dealer performs them, the brake lining field is filled with a measured thickness of the lining and an estimated mileage of existing use (front and back). They would need to remove the wheels to inspect and perform the job properly. No mention of assuring torque of lug nuts.
Did they measure the voltage or output of the power steering?
How did they check the BELTS??
ChevySS....you seem like a bright guy, but you were sold (even it it was free) a bill of goods. IMO.....but at least the oil change was free.
JWA
16
06-21-2014 12:16 PM
bigjacksauto
Maintenance and Upkeep
17
06-08-2013 11:58 AM
badassbowtie
23
05-12-2013 02:01 PM
