Front Hub Replacement 2009 LS
Old 11-30-2013 | 10:55 AM
I just can't go until April !
Old 11-30-2013 | 10:06 PM
maddawg's Avatar
My skill is not the problem. I have been working on my own cars for 30 years. I am going back and forth now between Florida and my house in Minneapolis. No place to work on it here and all my mechanic tools are at my house in Minneapolis with an unheated detached garage.
I am going to try a place in Orlando on Monday and see if they can give me a better price. They have a 5-star Yelp rating with over 30 reviews.
Thanks.
Old 12-04-2013 | 12:13 AM
maddawg's Avatar
3rd Estimate
$320 + tax at a shop in Orlando.
I ordered a hub assembly off Amazon for $49.56
I am going to try to get a mechanic I know to do it. I am back in Minneapolis now and it is way too cold to work in the garage.
Old 12-04-2013 | 08:27 AM
bundle up Buttercup!, if you're in a garage out of the wind, this shouldn't take to long, but if your mechanic guy will do it for a nominal fee, then it is worth the money.
Old 12-09-2013 | 09:40 PM
maddawg's Avatar
Well, no desire to work in below zero F temperatures.
Old 12-10-2013 | 09:01 AM
OldSchool57's Avatar
If you do decide to DIY, they are very easy to change. I changed both of mine and was very suprised how easy they came off. You will need a new axle nut also which is cheap from just about any parts store. Just remove wheel, remove axle nut,remove brake caliper and hang it from strut spring with a wire or hook so you don't have to undo brake line, slide off brake rotor, remove three bolts on inner side of housing that hold hub to housing, a little tap and it will fall out, install in reverse order. I took maybe 15-20 minutes per side including the wheel removal/install. Don't forget a new axle nut is highly recommended, I can't remember the torque but you can find it with a little research.
Old 12-18-2013 | 12:50 AM
HHRNole's Avatar
Maddawg, Where in Tally are you? I know a few shops around here that won't rip you off. BTW the hub you got at Amazon probaly won't last that long,I bought a set and changed them myself about a year ago.Now I noticed I'm getting a little noise out of them again.Next time I'll spend a little extra and get Timken hubs.
Old 12-18-2013 | 09:41 AM
X2 on the Timkens, worth the extra $ have lasted since 58,000 miles and I now have 148,000 on the HHR
Old 12-18-2013 | 04:34 PM
Kst8er's Avatar
what about Moog or Raybestos hubs?
Old 12-19-2013 | 08:06 AM
I can't say I haven't used them yet!
Quick Reply: Front Hub Replacement 2009 LS
