Front Hub Replacement 2009 LS
Old 12-23-2013 | 08:06 PM
nrvous1's Avatar
just ordered my hubs off Ebay for $125. I will be replacing both myself. seems fairly easy.
Old 12-26-2013 | 06:09 PM
maddawg's Avatar
I am not in Tallahassee right now. I think the cheaper bearing will last as long as I need them. The car already has 115,XXX miles. I can do myself when I have a heated are. I am in Minneapolis right now. It has been below zero most days lately. Who are you using in Tallahassee? Thanks.
Old 12-28-2013 | 11:33 AM
nrvous1's Avatar
Well, just replaced the hubs on my 2011 lt and I'm still getting a bad left front abs/hub on the scanner. I think I may have damaged the wire leading into the car and the hub was actually fine. This happened when I swapped springs from factory to the canucks. The spindle dropped and was completely supported by the wire connected to the abs sensor. Ever since then I'm getting the abs/hub message. Any ideas from anyone?
Old 12-28-2013 | 12:04 PM
The wire got damaged. Fix it.
Old 12-28-2013 | 02:08 PM
nrvous1's Avatar
Is there an easy fix? Or am I going to have to splice and either solder a new connection on? Is there a way to see exactly where the damage done to the wire is?
Thanks for the quick response.
Old 12-28-2013 | 02:50 PM
  #26
You stated everything. You have to find where it's broken, then splice it. I would be guessing that a pin or 2 in the connector got yanked out of it's spot.
Old 12-28-2013 | 03:51 PM
  #27
nrvous1's Avatar
Thanks Don. I'm going to pull the wheel off again tomorrow and start looking at the connection.
Old 12-29-2013 | 04:57 PM
  #28
nrvous1's Avatar
Well, found a cut in the wire leading from the fender well behind the driver side strut. I used butt connectors and used heat shrink on the abs wire connector and still did not fix the error codes. I think I may just have to give in and take hhr into a local shop.
Old 12-29-2013 | 08:14 PM
  #29
the_shmoo's Avatar
Did you try disconnecting the battery to reset the ECM?
Old 12-30-2013 | 08:03 PM
  #30
nrvous1's Avatar
Yes I disconnected the negative terminal from the battery for about 10 mins with no luck.
Quick Reply: Front Hub Replacement 2009 LS
