Front Hub Replacement 2009 LS
Old 12-30-2013 | 08:34 PM
  #31
Lucky's Avatar
If you have a meter you can check the resistance value at the sensor then trace the wire back to the abs module to find your wiring problem. Check the new sensor first. It would not be the first time that a new part failed out of the box.
Here is a wiring diagram for the abs sensors
Old 12-30-2013 | 08:39 PM
  #32
nrvous1's Avatar
Thanks Lucky. A friend of mine has a meter and I will try and test by this weekend to see where the problem is at.
Old 01-03-2014 | 05:42 AM
  #33
maddawg's Avatar
Axle Nut Torque
What is the axle nut torque setting? I think I remember 155 ft lbs. Is that right.
I had to go to Chevy for the axle nut. No parts stores could get them separate from the axle.
Old 01-03-2014 | 05:48 AM
  #34
Lucky's Avatar
Axle nut torque is 155 ft lbs.
Wheel bearing to spindle is 85 ft lbs
Old 01-03-2014 | 08:56 AM
  #35
re torque the bolts and the axle nut after a few days, just to make sure!
Old 01-03-2014 | 01:25 PM
  #36
They don't list the nut by application. You need to get the specs and have them play in the nuts&bolts bins. I think I did actually find them on either Autozone or Advance website, when I was looking for them. But then I found that they came with the axles.
Old 01-04-2014 | 09:52 AM
  #37
HHRNole's Avatar
I am not in Tallahassee right now. I think the cheaper bearing will last as long as I need them. The car already has 115,XXX miles. I can do myself when I have a heated are. I am in Minneapolis right now. It has been below zero most days lately. Who are you using in Tallahassee? Thanks.
Jeff's out past Capital Circle on 27N (just past Sonic & Hardee's) is a good one. Known Jeff for a long time since he had his shop next to the motorcycle shop I had and he's always been fair and honest.Most of my work I do myself though since I know how and have the tools.As far as the nut goes,they can be gotten at O'Reilly's under the Dorman brand. Give me a PM when you come back Tally way and maybe we can get together.Thanks
Smoke Wagon
"How To" Tutorial Library
89
03-21-2019 12:18 PM
Nat
22
10-16-2014 09:10 PM
gvander
06-11-2014 04:57 PM
kellyandbill2010
04-30-2014 05:21 PM
Doyletj
06-05-2013 08:33 AM
Quick Reply: Front Hub Replacement 2009 LS
