Frt Marker Bulb Replacement
Old 09-28-2010 | 05:50 PM
bossrod's Avatar
Is there any thing special to changing one of the front marker lights? I assume it is behind the fender weld but are the clips just push/pull?
Old 09-28-2010 | 06:20 PM
oldpanman1's Avatar
A Simple Chage
You are right. The front side markers are in the fender well behind the plastic paneling. Once you are in there, the mounting bracket twists loose and the bulb pulls out of bracket.
Old 09-29-2010 | 05:15 PM
asanti's Avatar
Easy job once the Christmas trees are pulled. I did mine in 5 min flat.
Later
Allex
scuba05477
07-29-2024 11:59 AM
Dementors1
Maintenance and Upkeep
32
12-25-2021 06:33 PM
peter van
06-14-2017 11:49 AM
shaginwgn
06-01-2012 11:09 PM
RICK167448
07-12-2010 10:32 AM
