fuel pump?
Old 04-11-2011 | 08:38 PM
BlackknighT's Avatar
Originally Posted by CrazyCarKid
But the HHR is CAN, so OBDII wouldn't do you any good.
CCK-most newer scan tools come with CAN as well as some slightly older ones. I have an slightly older ACTRON that has CAN as well as the below Equus 3130 that I bought from Pep Boys on some wacky special a couple of years ago for $125. I keep the actron in my car and the equus at home.
http://www.iequus.com/Product/Detail...6-9633D987F5C2
Old 04-11-2011 | 08:54 PM
urbexHHR's Avatar
Yeah, I know a lot of them have both. In fact, most that have CAN are OBDII compatible, but not all OBDII are CAN compatible. I just want to clarify that, so no one would buy just an OBDII.
Old 04-11-2011 | 09:20 PM
Good point.
Old 04-13-2011 | 08:47 AM
Brucet's Avatar
Dealer is replacing the fuel pump. No charge, under 'drive train' warranty. Gave us a free rental while the work is being done. I will let you know how it all goes.
Old 04-16-2011 | 02:17 PM
Brucet's Avatar
Apparently there is a small valve which prevents the fuel from returning to the fuel tank when the engine is turned off. This valve failed.
Replaced pump and valve and all is now well.
Cost me $0.00.
Old 04-16-2011 | 09:46 PM
.......and we never did hear what the code was!
Old 04-20-2011 | 01:19 PM
kornellred's Avatar
My OBDII scanner works on my 2007 HHR LS. Every time, no problem. What is CAN anyway?
Old 04-20-2011 | 01:27 PM
kornellred's Avatar
I just googled my own question. OBD is a generic shorthand for On-Board Diagnostics, the Roman numeral II is for the improved version, and CAN (Controller Area Network) largely has to do with communication protocols. Therefore, CAN is an enhanced version of the OBD system. Same connector, different way of talking.
Old 04-21-2011 | 01:48 AM
Good job man!!! Someone actually used a search engine. Wish you could give lessons on that
Seriously, the information is generally out there, and one can get a quicker response doing their own search, rather than posting a question. And with your followup, we all learned something, or clarified, or reinforced information for the more experienced.
Thanks guy. :)
Ijazzu
05-05-2015 01:29 PM
Jeda13
09-19-2014 04:42 PM
2007OrangeHHRLT1
02-03-2014 04:45 PM
Mattasticbmx
2.0L Performance Tech
02-19-2013 11:38 PM
BeanWagon
07-02-2011 10:36 PM
Quick Reply: fuel pump?
