Fuel Range Issues
Fuel Range Issues
Merry Christmas y'all 🎅 🌲 🤶
For about a week my fuel range indicator has been way off. When I fill the tank it indicates 365-375 miles left. Then fluctuates the entire time. It usually starts off around 420 miles.
It is based on the amount of metered air being consumed at any given second. If you are accelerating more air is being induced therefore fewer MPG therefore fewer miles to go. It varies radically, not meant to be constantly monitored.
Uless you have a hole in the tank or puddles of gas, relax.
Yes, the fuel range can be very misleading, on a long highway run, I would try to calculate fuel stops, they never worked out, because of hills and traffic, valleys and construction, not very accurate, as it would be on straight flat roads.
I'm not stressed out by this latest quirk. Just checking to see of anyone else encountered this previously.
