Greasing end links
Old 07-10-2016 | 09:17 AM
If you have the 12 inch links, that can clunk when the contact the LCAs. Should be 10 inch.
Just saying it one more time.
Old 07-10-2016 | 03:41 PM
aradmahogany's Avatar
They are the 10 inchers! I read about that issue numerous times lol
Old 07-11-2016 | 10:45 AM
Cat Man HHR's Avatar
Originally Posted by aradmahogany
MOOG SWAY BAR LINKS WITH GREASE FITTINGS. because my attempt at removing the nut was a completed failure, and I suspect whomever replace the originals used an impact driver.
The nuts for the links are self locking and are a task to remove by hand but it can be done. You would need a breaker bar longer than 2 ft to get then to break lose.
What is also nice about the MOOG part is the nut on the stud. There is a lot more material there to use your wrench to hold it verses the OEM part.
BZERKED
12-28-2012 01:25 AM
grocerygetter
05-15-2011 10:26 AM
Stryker
02-16-2011 07:33 PM
08blackHHRSS
12-08-2010 12:45 PM
Quick Reply: Greasing end links
