How to change your own oil.
Old 03-15-2010, 06:54 AM
  #131
pitbull76's Avatar
Just did this job on my SS yesterday. This post was helpful for sure. As many people noted, most 32MM sockets won't fit on the filter without interference. The socket I already had didn't either, but I got one that works at Sears for $8.69. It is a 12-point 32MM socket, and is short enough to avoid interference.
pitbull76 is offline
Old 03-16-2010, 02:31 PM
  #132
sfdualsport's Avatar
Rhino Ramps are Great
I read this thread and saw somebody mention Rhino Ramps (8000 lbs.) , picked up a pair on sale and they do have plenty of clearence for the air dam. The stealership just did my first oil change and filter for free and put 10W-30 bulk oil, when I complained and showed them the manual they said it would be fine, they rotated the tires and did not reprogram the TPM,s also. Needless to say its a brand new car so I dumped the oil and put Castrol 5w-30 which is on the GM approved list, had them reprogram the TPM's because I was so pissed at them and needless to say I will never go back to that dealer again. They really suck, their service sucks, it was a tire rotation and and an oil change not brain surgery! BTW I also own a crown Vic and tried the Rhino Ramps, my wife is very happy that I don't have to turn off the air supession and have her climb in the trunk no more because of the clearence issue.
sfdualsport is offline
Old 03-19-2010, 04:25 PM
  #133
StaticAZ's Avatar
Solman98:
I posted this before but, on my 2010 - 2.2 , I cannot get my 1 - 1/4" socket to seat on top of the filter housing. The manifold is too close. The socket I have is 1 - 3/4" tall and it sits on an angle.
Can I ask where you got yours? If I could get it to seat looks like it would
work but, I figured I would have to use a 1 - 1/4" box wrench. Posted this elsewhere but thought it may help someone else to put it on this thread also..
Just an update .....found the socket that was designed for this on Amazon.com $6.95
http://www.amazon.com/Lisle-14700-Fi.../dp/B0009OMYAQ
StaticAZ is offline
Old 03-20-2010, 11:56 AM
  #134
Quietwings's Avatar
Hi all, got everything I need to change the oil in "Horatio." Should be pleasant. My first post here, glad you're all out there in this network for the help, thanks!
Horatio's Stock, been running Mobil 1 full synth since we got him last Aug '09 with 19k, now 34k. Has been such an awesome car for us with two kids and a full time work vehicle for our cleaning business.
Quietwings is offline
Old 04-18-2010, 06:54 PM
  #135
Don06's Avatar
I usually start with the beer!
Don06 is offline
Old 04-19-2010, 12:56 AM
  #136
Welcome Quietwings-
That's what I use also, M1...
sleeper
sleeper is offline
Old 04-19-2010, 05:50 AM
  #137
solman98's Avatar
Originally Posted by StaticAZ
Solman98:
Cheap AmPro socket from Advance. It's only used for the oil changes.
solman98 is offline
Old 04-19-2010, 09:27 PM
  #138
Quietwings's Avatar
Oc
IT WAS SO EASY!!! Great info. Thanks.
~Qw
Old 04-25-2010, 06:46 PM
  #139
Old Lar's Avatar
I changed the oil and filter today in my 06 HHR. The dealer did it last time and torqued the he[[ on the drain plug. What a pain to get that loose. I used my largest torque wrench on it to get it loosened. I had 10,300 miles with Mobil 1 and 15% oil life left.
I spent most of my time working on loosening the drain plug, so it took me about 45 minutes.
Old Lar is offline
Old 04-28-2010, 07:54 PM
  #140
nuc
nuc's Avatar
Thanks for the nice explanation AND PICTURES. Just took my little beauty to a quick change place and they couldn't get the filter off. Had a big, deep-well socket. No I know why it didn't work. Got free oil, though!
nuc is offline
Quick Reply: How to change your own oil.
