How hard to change trans fluid?
Old 09-29-2014 | 06:04 PM
Camaross94's Avatar
2011 with 2.4L auto. I have not done any trans service on any newer cars so not sure what to expect. How hard is it to change filter? Local shop who does great work said $140.00 for everything. But curious if I can do it myself without special tools an save money. Thx.
Old 09-29-2014 | 06:18 PM
Type "changing transmission fluid" into the search box and several threads will come up detailing the exact how-to. Other search terms will get several other threads.
Bottom line: do you mind getting ATF all over yourself and your floor, then it's fairly easy. $140 for ATF & new filter is a fair price. The Dexron VI will run about $50, filter & (good) gasket will run about $30.
Read your Owners Manual for the recommended change interval. Mostly doesn't need it.
Old 09-29-2014 | 06:29 PM
Camaross94's Avatar
10-4 . I'm at 50,000 miles an it's never been serviced so it's due.
Old 09-29-2014 | 06:38 PM
What? Has the car been a Taxicab?
Go right ahead, if you want to spend your money, but you really should read the Owners Manual. Won't hurt anything but your wallet, won't help anything either.
Old 09-29-2014 | 07:02 PM
Camaross94's Avatar
I have nothing in my 2011 manual for mileage. But I see people saying 100,000 before changing. But they did it at 75-85 instead. So I'm fine for along time then.
Old 09-29-2014 | 08:21 PM
Look on page 6-23 and then the direct to page 7-3. IF the vehicle is used as a taxi or police car then every 50,000 miles, otherwise never.
Old 09-29-2014 | 11:50 PM
oldracer's Avatar
I changed mine about 122,000 miles or so. I found a large plastic storage container about 6 inches deep and wider and longer than the transmission bottom AND it had wheels on it. My wife bought it at Walmart years ago. The procedure is easy to follow and I added the amount of fluid called for in the repair manual/owners manual. Make sure to torque the pan bolts as they will compress the gasket and it will leak otherwise.
It was easy to do, no mess or spills.
Old 09-30-2014 | 06:04 AM
They also leak if over torqued.
Old 09-30-2014 | 03:24 PM
Camaross94's Avatar
Thx guys!
Old 10-02-2014 | 04:55 PM
oldracer's Avatar
I just remembered I found a series of pictures of some Russian (?) mechanics, somewhere on the East Coast that showed in detail how they did it. They had a pit to stand it where I used the large plastic clothes container. If you search you should be able to find them.
Quick Reply: How hard to change trans fluid?
