Input Speed Sensor Location
I been trying to find where it's located and haven't been able to find any information on its location. Does anyone here have any ideas or a picture of its location I need to replace mine.
1st post says input. 2nd says output. So which is is ? Also, do you have a 5 speed or auto ?
Fwiw. I think Snoopy's reply is correct about the location being by the output shaft.
I looked the part up and Autozone had a pic showing it in that spot.
Got the GM part number which is 24218077, but no location or diagrams. Oh my fault for not saying it clearly the one on the output shaft is the output speed sensor(already found that one on the vehicle not the one i need ), and I am looking for the input speed sensor -> http://www.autozone.com/engine-manag...008_2633_1277/
Auto
Auto
The one you posted from autozone is an input sensor used for trans control. Number 46 in the diagram.
13 - TFP Manual Valve Position Switch Assembly
46 - Input Speed Sensor
62 - Output Speed Sensor
305 - 1-2 and 2-3 Shift Solenoid Valves
312 - Pressure Control Solenoid
335 - TCC Control PWM Solenoid13 - TFP Manual Valve Position Switch Assembly
Turbo_Tomater
03-27-2013 02:26 PM
