inside door panel insert
Does anyone know where I can find the rubber door pull insert that covers the screws. I am missing a black one for the rear door on my 08. Cant seem to locate a part number or its correct name.
Thanks
Thanks
I think what you want is actually the liner, as GM Parts Direct is calling it. If this is correct it is only $2.58 each.
15146916 - Liner W/O PANEL VAN Right
Left has the same part number
Add to Cart: 15146916 LINER
Rubber Liner for Door Grips - they hide the screws at the bottom of the door panel grips: (suggested by 843de)
- LINER - Front & Rear Side Door Trim Finish - GM P/N: 15146916 (Fits 2006-2008)
- LINER - Front & Rear Side Door Trim Finish - GM P/N: 25874249 (Fits 2009-2011)
SlickRick2
Mods - Interior
09-26-2012 06:40 PM
