Lower control arm, rear bushing bolt/pin
Old 07-19-2023, 01:29 PM
Originally Posted by FirstGenHHR06
Ok so I have the green puce but it's not green and no threads. Also the old bolt is in 3 pieces I got a new one from the dealership, but now it's the mater of putting that but back in (that has no threads) without putting it on the lift cause my man's vehicle is on it with no tires
Puce is a color that is not green. That first sentence just makes no sense.
RJ_RS_SS_350 is offline
Old 07-19-2023, 02:42 PM
Let’s go with typographic error, the green puck? Or green piece.
Oldblue is offline
Old 07-19-2023, 02:44 PM
I think he meant “green piece”.
firemangeorge is offline
Old 07-19-2023, 06:54 PM
They're the ones trying to save the whales, right?
Old 07-20-2023, 06:31 AM
No, they’re Green Peace.
Oldblue is offline
Old 07-20-2023, 06:46 PM
PulpFriction's Avatar
Close. Greenpeace. One word. A bit more than saving whales. Have a look.
I'm thinking about going to the drawing board (literally, I still have one, even tho I don't use it or CAD either much anymore) and try to design a solution for spun cage nuts. Anyone have any thoughts as why a cage nut was used in the first place?
PulpFriction is offline
Old 07-21-2023, 06:08 AM
It’s inexpensive.
fastsuv came up with a good solution, and it worked bolt , washer then nut.
Oldblue is offline
Old 07-21-2023, 07:07 AM
Originally Posted by Oldblue
It’s inexpensive.
Yeah, but so is a weld nut. Someone thought it needed to float. I don't see the need, unless they thought they couldn't hold the tolerance to the front guide holes well enough to avoid assembly problems.
...fastsuv came up with a good solution, and it worked bolt , washer then nut.
Gotta look that up. I was thinking just a strategically shaped tapping plate that would slide in place and can't rotate no matter what, no weld required. But I've never had to deal with this so I don't know the territory. Also not used to having no reference drawing to work from.
Old 07-21-2023, 08:31 AM
A slide in plate with a nut welded to it would work.
Oldblue is offline
Old 07-24-2023, 09:25 PM
I like that. Lighter, and might be easier to install.
Quick Reply: Lower control arm, rear bushing bolt/pin
