mobil 1
Old 06-26-2013, 05:35 PM
skyline26's Avatar
mobil 1
whats the difference between the mobil 1's? i see synthetic and full synthetic options..
which ones are you guys using? i want to try switching over from Quaker State synthetic
skyline26 is offline
Old 06-26-2013, 06:09 PM
Snoopy's Avatar
Anything by Mobil marked MOBIL1 is a "full" synthetic.
Anything by Mobil marked dexos approved, may or may not be a full synthetic. I think you are confusing the terminology. The "key" as stated above, is MOBIL 1.
And hell what do you know, I can now post again after 5 days.
Snoopy is offline
Old 06-26-2013, 06:32 PM
wmsburghhr's Avatar
OP may have found what I did when I googled Moble 1
Mobil 1 0W-30 Advanced Fuel Economy Full Synthetic Motor Oil,
Mobil 1 Extended Performance 5W-30 Full Synthetic Motor Oil
Mobil 1 High Mileage 5W-30 Full Synthetic Motor Oil,
Mobil 1 5W-30,
My head is starting to spin after google turns all this up at walmart. Think I'll just mix them all together just so I am covered.
wmsburghhr is offline
Old 06-26-2013, 06:34 PM
skyline26's Avatar
interesting..here in canada the stores say just "synthetic" ..yet the US stores say "full synthetic" ..and the price for a 5L jug is double here in canada as well, o joy lol
Old 06-26-2013, 07:51 PM
prod's Avatar
I get Mobil 1 when it goes on sale for about $30 at canadian tire or partsource, happens every 6 months or so. I've used regular and extended performance. Quaker state is ok and Pennzoil are also good, just make sure its full synthetic. There are websites that test and rate them.
EDIT: mobil 1 is 30% off at canadian tire starting this friday
prod is offline
Old 06-26-2013, 11:08 PM
I'd avoid the M1 "high mileage" unless you have hi miles with some weeps or small leaks.
sleeper is offline
Old 06-26-2013, 11:13 PM
Costco sells it 25.00 a case....
welcome back Snoopy.
SS fan is offline
Old 06-26-2013, 11:16 PM
agreed, Welcome back Snoopy..
Sam, how many qts in a case ?
Wallyworld is like $22. for a 5 qt jug. M1 or Castrol Edge....
sleeper is offline
Old 06-27-2013, 06:15 AM
The GM standard oil ratings are 1 difference you will see between the different Mobil One choices.
Before the Dexos inclusion, there was the 2 oil rating requirements for the HHR.
GM6094M- 2.2, 2.4 engines
GM4718M- 2.0 engine
If you read the ratings on the back of the container, you will notice that most Mobil Ones will say GM6094M. Only a few carry the GM4718M.
I use the regular Mobil One which has the GM4718M.
firemangeorge is offline
Old 06-27-2013, 06:19 AM
Tominator's Avatar
Part of it is shelf space. The more shelf space, the more sales. Detergent, toilet paper, car wax, etc. Works like that for any commodity you buy. The MFG varies the product slightly because of laws regarding retailing.
Tominator is offline
Quick Reply: mobil 1
