Not so perfect
Old 02-25-2013 | 11:42 PM
Maphet's Avatar
Not so perfect
changed out my air filter today and found that my new to me 07 HHR LT has a broken air box bracket. where do i get a new on or do i need to get one from a junkyard
or dealer?
Old 02-25-2013 | 11:46 PM
Being it's a kinda flimsy bracket anyhow, I'd beef it up & you won't need to buy another..
Simple dealio..
Old 02-26-2013 | 12:14 AM
Maphet's Avatar
Lightbulb thanks Sleeper
thanks Sleeper then i will ask my machinist buddy to welled it back together and make it stronger.
Old 02-26-2013 | 01:18 AM
Cool, if he 'fishplates' it & welds that, it should NEVER be an issue again.
Old 02-26-2013 | 09:34 AM
LawDog88's Avatar
FWIW, I bought a brand new one from gmpartsdirect dot com and have not had a problem with it. Like $20. I did buy two, in case I wanted to reinforce it with the second, but there has been no need.
Old 02-26-2013 | 12:56 PM
Yes but IIRC this is the 2nd bracket yours broke..
Old 02-26-2013 | 01:39 PM
LawDog88's Avatar
The 1st one that came on it was stock. the replacement one I got, was from another member and had already been under stress of use for nearly 80,000 miles on their vehicle. This last replacement was bought from gmpartsdirect dot com to fix. Still have the other one. Not being used. Keeping it just in case.
Old 02-26-2013 | 02:11 PM
Hopefully 3rd time (replacement) is the charm for you...
Old 02-26-2013 | 05:29 PM
LawDog88's Avatar
So far so good.
Old 02-26-2013 | 09:04 PM
Switched to the K&N don't think it will be a problem now....
moonsign
0
11-04-2012 09:22 PM
bunkie
South Pacific
25
09-14-2009 09:58 AM
silverjc
03-16-2009 08:34 AM
MWG2
01-02-2009 12:33 PM
saltyfishguy
04-13-2008 02:03 PM
