O2 sensor question
Old 12-26-2014, 05:41 PM
Rotor's Avatar
O2 sensor question
Hey fellas;
How reliable are the autozone/advancedautoparts/napa/oreiles autparts sensors? I need to replace the upstream on my '06 HHR.
Regards,
Rotor
Rotor is offline
Old 12-26-2014, 05:48 PM
Originally Posted by Rotor
Hey fellas;
Regards,
Rotor
I moved this into it's own thread since it made no sense as originally posted.
I would suggest getting a NGK/NTK brand sensor, not a generic or Bosch. If that is the question.
Why do you need to replace the upstream sensor?
donbrew is offline
Old 12-26-2014, 06:14 PM
Rotor's Avatar
Need to replace due to P0135 circuit bank1 sensor 1. Already checked the fuse. Thank you for brand info, as it was my question.
Edit: those are are the more expensive ones hehe, well, guess you get what you pay for, any other input from the group?
Regards,
Rotor
Rotor is offline
Old 12-26-2014, 07:19 PM
The cheapo ones and Bosch will not register correctly with the ECM and you will have MIL lights for the same issue as now!
Oldblue is offline
Old 12-26-2014, 08:43 PM
Rotor's Avatar
Thank you.
Rotor is offline
Old 12-27-2014, 01:52 PM
It's worthwhile checking the connection at the sensor to make sure it is clean and making a good contact before replacing the sensor. I've had one that I almost replaced years back - but found the connection needed a good cleaning - and am still using the original sensor. Might save you some $'s.
whopper is offline
Old 12-27-2014, 02:09 PM
BTW if went to dealership to buy an OEM it would be NGK/NTK.
donbrew is offline
Old 12-31-2014, 10:24 AM
Rotor's Avatar
Thank you guys, will check connector. Will reply back when I get to it.
Rotor is offline
Old 02-04-2015, 01:09 PM
Rotor's Avatar
Hi all.
I went with the Denso brand sold at Adv APs. It was 30.00 cheaper than NGK and worked like a champ.
Rotor is offline
Old 02-04-2015, 01:59 PM
solman98's Avatar
The thing with O2's is, one day they work, and then they don't. Just be careful and not let the tip touch anything during install. First upstream O2 I replaced I went with NKG, it's lasted a whopping 13 months. I elected to go cheaper the last time and so far so good.
The DENSO I replaced in the downstream one is still going strong.
What really sucks is, I only replaced the first time becaue I was in there replacing the cat and did it as preventative maintenance......
solman98 is offline
Quick Reply: O2 sensor question
