oil filter
Old 02-26-2008 | 05:12 PM
asherdav's Avatar
Smile oil filter
What a shock to find a element in the new filter box. Now where to put it? 2.2 08
Old 02-26-2008 | 05:23 PM
Black Rose's Avatar
Here's where to put it
https://www.chevyhhr.net/forums/maintenance-upkeep-50/how-change-your-own-oil-10546/
Old 02-26-2008 | 06:33 PM
SIRESMERPH's Avatar
you can take that filter of yours and stick it where the sun dont shine....
right up under the hood cus that's where it goes...yep!
Old 02-26-2008 | 09:25 PM
Smoke Wagon's Avatar
looks like the write up didnt mention replacing the o-ring on the filter cap.
I think the authoir just forgot to mention it, but the filter element should come with a new filter cap o-ring. Change that, and smear a little new oil around the o-ring to prevent any tearing as it goes in.
Old 02-26-2008 | 09:34 PM
Lone Ranger's Avatar
Why replace the o-ring if its still in good shape?
Old 02-26-2008 | 10:56 PM
...I always replace any o-ring when a new one is supplied. If it's subjected to corrosives, pressure, heat cycles, expansion and compression, and is made of silicone or rubber, all I ask is...
why NOT change it? The filter comes with a new one. And if the old one should fail, it'll cause a bigger mess than the current drain plug design
Just my 2 cents.
Old 02-26-2008 | 11:15 PM
oneton's Avatar
Whats wrong with the current drain plug design???
Works just like all drain plugs, you have to hit the drain pan or get a bigger pan
Old 02-27-2008 | 12:29 AM
Black Rose's Avatar
The AC Delco filters that I buy do not come with an o-ring. I think only Wix filters come with the spare o-ring.
Old 02-27-2008 | 12:35 AM
Snoopy's Avatar
Thank you Black Rose....I was thinking the same thing.
Purchased a dozen Delco filters so far (shared with friends). NONE came with the "gasket". Not that it's not a bad idea.
Oh you know...I think if you purchase the Delco filter that comes with the filter cannister lid, they also provide the o-ring.
Old 02-27-2008 | 08:11 AM
solman98's Avatar
The Pure One filters I buy don't have the o ring. It also looked fine and sealed well since then. The o-ring itself does not touch oil.
