Old Cabin Air Filter
So I just took out my old cabin air filter. I was a bit surprised with it's condition. I was expecting it to be dirty...but not to be mangled.
I looked inside the filter housing...and there is hard plastic inside that appears to be what's causing the mangled mess. Unless whoever put the last one in didn't go upwards with the filter.
Most likely.
You can remove the plastic cowl cover to both check the install of the filter and clean out the leaves.
And you can bet there is a bunch in there.
The cowl cover does not seal very tight.
