P0011 , 2011 , 2.2 engine
Old 05-24-2022, 01:58 PM
Rocket Dawg's Avatar
This code just showed up today. Camshaft position sensor. bank b or something like that. ( I'll have to recheck to be sure). Went to Rock Auto to order another 1. AC Delco . On Youtube it sez there are 2 of these solenoids. Do I order 2 of the same thing? Or are there 2 different part numbers? An oil change will take place at this same time... It's a 2.2 engine 207k on the ticker. thanks.
https://www.rockauto.com/en/moreinfo...t=7192&jsn=988
Rocket Dawg is offline
Old 05-24-2022, 02:15 PM
It takes 2 for sure. But they look nothing like the Rock Auto picture
Old 05-24-2022, 02:17 PM
How do they come out? I dont see a retainer of ant sort. Thanks
Old 05-24-2022, 02:29 PM
You need to check the code again, maybe with a different reader. That code is not for HHR.
RJ_RS_SS_350 is offline
Old 05-24-2022, 02:48 PM
Do you mean P0011? Please confirm the code prior to ordering parts. We’ll get you straightened up!
Oldblue is offline
Old 05-24-2022, 02:50 PM
Okay, just went a plugged it I again .This is what it actually sez, Camshaft Position Actuator A Bank 1 Timing over advanced. The 2011 was for the year of the HHR, not the code number. The code is P0011. sorry for the confusion.
Old 05-24-2022, 02:52 PM
Hmm, no actual code?
https://www.obd-codes.com/p0011
Are you replacing the VVT actuator solenoid?
Oldblue is offline
Old 05-24-2022, 03:54 PM
Code is P 0011. First post was from my phone, fat fingers and the 2011 was the year of the HHR not the code. Sorry about that. P0011 is the code for sure, checked it 3 times. Car still runs like normal, although I'm done driving it till its repaired. There is a gray colored one and a black colored one. Hope I dont need a timing chain. Drove the HHR 225 miles on Sunday, Two 110 mile trips, no codes, it ran nice. Didn't drive it Monday, today at start up, the code showed up
please edit title of thread.
Old 05-24-2022, 05:05 PM
I would change both solenoids, 10 mm socket and a 6 “ extension with a ratchet, 3/8 drive . To get the bolts out, then wiggle the old ones and pull straight up with a pair of pliers.
Clean the area first.
https://www.chevyhhr.net/forums/how-...13-14-a-28779/
Oldblue is offline
Old 05-24-2022, 05:48 PM
Thanks. Just cleaned the area and ordered both. The local parts guy will have them here in the morning. I'll report back with the results.
Quick Reply: P0011 , 2011 , 2.2 engine
