Radiator Drain
Drain pet**** is at the bottom, rear of the rad on the passenger side. You likely won't be able to see it from topside, but if you feel around for it you will find it. It has a big butterfly shaped handle for your fingers and is made of plastic. They can be fragile, so do not use pliers on it - only loosen-tighten by hand.
I found that the thingie is way too tight to turn by hand, I did use a fair of pliers. I agree that is a horrible idea, but I was under my only car at the time. I believe that there is a special tool for it, or maybe try one of those "universal as seen on TV" sockets, but there may not be enough clearance.
BTW, it looks more like a casting registration mark, than a petthingie.
Well actually there is a tool, more properly a set of Pet...ummm....rooster sockets made by Thexton Tools. You can find them at Sears for $13.95, and I'm sure they are available at auto parts stores too. I picked up a set last year and they work great on stuck Petroosters...silly censoring function.
Sear part number is 00901541000, can't post up a direct link because the censoring function here doesn't like Petroosters.
