Radiator hoses, 1st design or 2nd design? 2006 HHR 2.4
I am thinking of replacing the radiator hoses, heater hoses, and oil cooler hoses on my HHR since they are over 10 years old (car manufactured September 2005) and it has 217k miles on it now. It was flushed about 4.5 years ago. The question I have is when looking at hoses I see 1st design and 2nd design on some. Which should I get? Thanks.
Interesting, never knew this. But with your date of manufacture, I'd go with 1st design. I'll add that I noticed on many newer models, they had a silver looking radiator and mine was black (viewing through the grill).
Any pic of the 2 designs? Might just be a bend adjustment.
I didn't see any difference, and the parts store only asks, "With or without oil cooler" when you get them. Rock Auto and other sites shows both ways, and it looks like the the ID is different.
Don't know if this is useful, but I copied this from the Gates catalog.
It's for the 2006 HHR.
4-Cyl. 2.4 L
Serpentine Belt .................................................. ............... GK050400
Tensioner Assy. .................................................. .............. 38177
Tensioner Pulley .................................................. ............. 36193
Upper Radiator Hose - Front ............................................. 23163
Upper Radiator Hose - Rear; (1 1/4" x 3") ........................ 24020
Lower Radiator Hose - Front; 1st Design .......................... "21942
Lower Radiator Hose - Rear; 1st Design .......................... 23162
Lower Radiator Hose - Rear; 2nd Design ......................... 23164
Heater To Thermostat Hose ............................................. 19848
Tee To Oil Cooler Hose; 1st Design ................................. 19847
Oil Cooler To Thermostat Hose ........................................ "28475
Filler Pipe To Rad. Hose; (3/8" x 20") ............................... 28409
Thermostat To Heater Hose ............................................. 19478
4-Cyl. 2.4 L
4-Cyl. 2.4 L
4-Cyl. 2.4 L
