Rear control arm bushings
https://youtu.be/ThMeUIZSCGY
https://www.rockauto.com/en/catalog/...+bushing,10449
Where to get them and how to replace them.
Prothane bushings use the OEM metal part
https://www.vividracing.com/-p-153023832.html
Here’s a photo
Here’s a photo
Interesting, part #16 is labeled as SUPPORT. Rear Axle Control Arm.
But none of the other parts in the diagram are labeled as a control arm. Maybe leftover nomenclature from older rear suspension designs.
#18 is labeled Axle beam insulator. INSULATOR - REAR (RR) SUSPENSION. Suspension Subframe Insulator.
What is 19 called?
Parts nomenclature is rather arbitrary, mostly driven by convention, often decided at a very low level.
Source: I have named a lot of parts, mostly in my early days as a detail draftsman. Whatever my simple mind put in the title block, unless the checker or some other senior person objected, became that part’s name forever.
I would have called 16 a bracket.
I know this is an older thread but today I heard a clunk from the rear of the car as I was backing up with somewhat of an acceleration. Heard it again as I put in in drive. Haven't had a chance to jack it up yet but Im guessing thats about the only thing back there that can cause a clunk. I have new springs and the rubber spring dampers installed along with newer shocks. Bearings spin free and are tight. Axle beam bushing time?
