Rear Stone Guard part # (the plastic ones)
Old 09-15-2015, 10:25 AM
a_bartle's Avatar
Does anybody have the GM part number for the plastic rear stone guards? I've been looking to get a set (since I do not have running boards) and those seem to be better than the clear film (which is currently peeling on mine).
Thanks...
Art
a_bartle is offline
Old 09-15-2015, 10:45 AM
LT4Man's Avatar
GM # 12499528
Splash Guards
Front & rear molded set
Black with "HHR" logo
I do not know if you can purchase just the front or just the rear.
Good luck!
LT4Man is offline
Old 09-15-2015, 11:03 AM
a_bartle's Avatar
No, I'm not talking about splash guards, but the rear fender guards (rather than the clear film). I believe they were putting them on the '07 models, or such I've read.
Thanks...
a_bartle is offline
Old 09-15-2015, 11:04 AM
prod's Avatar
I think he means the plates on the rear doors from the 06s. I think i remember a post about them, try the search box.
prod is offline
Old 09-15-2015, 12:08 PM
a_bartle's Avatar
I've tried the search feature, the only part numbers I've found are for the clear vinyl protectors.
The pic below is what I'm looking for...
a_bartle is offline
Old 09-15-2015, 12:31 PM
EXTERIOR TRIM - REAR DOOR for 2006 Chevrolet HHR (LT) All noted as discontinued parts, no longer available.
whopper is offline
Old 09-15-2015, 01:02 PM
a_bartle's Avatar
Thank you very much, yes that is what I'm looking for. I have a friend that works at GM, going to have him check if there is "any" inventory still around.
Also found a set of running boards at a junk yard (sadly it's about 3 hours away though...) that I might also consider (and scrap the stone guard idea). Trying to find info on how to remove them (I've found some data on installing them, but not a lot on removing them) and someone said something about a special tool....?
Thanks again...
Art
a_bartle is offline
Old 09-15-2015, 03:18 PM
VinceP's Avatar
The running boards are not hard to take of the donor. Star bit screws hold the brackets on. Make sure you get all of the hardware that goes with them. The rocker panels that are currnetly on your HHR however are a different story. I broke mine when taking them off. I dont remember hearing about too many successful removals without breaking them.
Love the running boards though so wasnt concerned about breaking the old rockers.
VinceP is offline
Old 09-15-2015, 05:19 PM
I believe there is a "how-to" on this site.
donbrew is offline
Old 04-08-2023, 07:57 AM
JBY
JBY's Avatar
Originally Posted by a_bartle
does anybody have the gm part number for the plastic rear stone guards? I've been looking to get a set (since i do not have running boards) and those seem to be better than the clear film (which is currently peeling on mine).
Thanks...
Art
gm 12499528
JBY is offline
Quick Reply: Rear Stone Guard part # (the plastic ones)
