replacing sway bar links
Old 09-30-2011 | 10:06 AM
  #51
AC66Bronco's Avatar
I see a lot of talk about needing an alignment or not after replacing a strut.
YOU DO NEED ONE!
It is impossible to get the camber right and with out proper camber you will chew through tires.
Yes it is set up in the top but not down at the knuckle.
Old 09-30-2011 | 11:46 AM
  #52
JoeR's Avatar
YOU DO NEED ONE!
Huh?? There is NO provision either at the top or the knuckle for camber adjustment!
Old 09-30-2011 | 12:11 PM
  #53
AC66Bronco's Avatar
Unless they changed the design from a 2004 saturn ION to a 2010 HHR I would Highly recomend getting it at least checked out.
I would bet it is off.
Old 09-30-2011 | 12:16 PM
  #54
JoeR's Avatar
WTF does a '04 Saturn have to do with an HHR anyway?
And, without ANY method of adjusting camber, the only solution is those eccentric bolts.
Also, how does and of your posts relate to the original topic of sway bar links?
Old 09-30-2011 | 06:34 PM
  #55
I agree.
THE ONLY STOCK adjustment on an HHR front end is the TOE!!! The camber and caster are pre-set by the strut tower at the engineer's draftboard, before it ever gets to the assembly line. If the caster or camber are out of spec, the a frame pull is called for, and the only reason to muck about with the camber is "other than" stock size wheels. This is one of the reasons the manufacturers adopted the McPherson Strut. Please put your "logic" hat on, this was not meant as a flame.
Old 09-30-2011 | 06:58 PM
  #56
JoeR's Avatar
Originally Posted by donbrew
I agree.
I'm having some real fun now! Now, how does the above bolded text have any relevance??
Group buy on "a clue" coming soon!
Old 10-01-2011 | 01:14 AM
  #57
JoeR - oh man, you know that EVERYTHING you read on the internet is true don't you?
Does "a clue" come in boxes, bags, or bottles? - never seen it on a shelf anywhere, so not sure what it looks like.
Old 10-01-2011 | 07:25 AM
  #58
I'm getting kinda old, I hope I get a clue soon. Can one be chocolate covered ??
Old 10-01-2011 | 07:49 AM
  #59
BlackknighT's Avatar
Chocolate Ex-Lax is a good stimulant.
http://www.amazon.com/Regular-Streng.../dp/B000052Y4H
Old 10-01-2011 | 08:22 AM
  #60
Thanks for the link, that stuff should keep a fella running !!
Quick Reply: replacing sway bar links
