replacing thermostat
I have a 2007 HHR 2.2L engine. I have to replace the thermostat, can anyone tell me how to do that? Or will I have to take into the dealer or a shop too fix this? Also does anyone have any idea how much this will cost? Just a ballpark figure will do.
cheap if you do it yourself ,just follow the bottom hose to the back of the firewall on drivers side and you will see it at the end of the hose it like round metal type cover with two bolts ... i think there 10 mil in size just unbolt and pull ,you will lose some coolant but it sits in the housing and replace make sure you take note how it sits in position for the new one ..and do not go cheap on the stat either ,and them top off fluid with dex cool good and save alot of money...
There is a very good tutorial on this repair in the "How To" section. Go either to the "Search" box at the top middle of the page OR To the "Forums" link and locate the "How To" under the General Discussion area. You will find something like this......
https://www.chevyhhr.net/forums/how-tutorial-library-21/how-save-%24350-00-thermostat-replacement-2-4l-p0128-24493/
