Is it safe to switch to full synthetic with high mileage?
Old 04-15-2015 | 12:53 PM
  #51
That Hutter was 1989 Ron was our engine builder for just the one season. This was a full race 468 c i dry sump oil system , nothing for exhaust past the header collectors!
Old 04-15-2015 | 05:42 PM
  #52
Snoopy's Avatar
OB....did you change the oil after each day's run??
Old 04-16-2015 | 05:23 AM
  #53
Three nights of racing Friday Saturday and Sunday. The sump tank held 24 quarts of oil and double remote filters.
Wow that would be spendy at today's oil prices!
Old 04-16-2015 | 05:55 AM
  #54
888's Avatar
888
Rotella comes in a blue bottle T6 5w40 full synthetic version that I've used in various mileage and era VW and Subaru gas 4 cylinders without any problems for a number of years. You can find it at Walmart or Tractor Supply. There is a T5 blend version and the usual white bottle 15w40 dino version.
I've never been crazy about 5w30 oils and the only 5w40's are usually only diesel formulations (similar to 15w40 dino oil).
I did know that Dexos was a GM certification rather than a brand, i did some research when I bought the Cruze turbo.
Thanks for the replies.
Old 04-16-2015 | 08:25 AM
  #55
Then you know Dexos is the ONLY cert recommended, already.
Old 04-16-2015 | 10:54 AM
  #56
rocket6763's Avatar
I have a 2007 HHR LT, I have used Valvoline Max Life full Synthetic Oil, and have since I purchased it at 64,000 miles, and have had NO consumption issues. If you use a synthetic media oil filter(Fram XG9018) You can go by you oil life monitor( I change mine when I get to 10% or less) Hope this helps, and by the way, the Valvoline full synthetics are actually rated higher in several categories over Mobil 1. I did my homework
Old 04-17-2015 | 07:06 AM
  #57
888's Avatar
888
Actually, I didn't, which is why I asked.
I rarely opened the hood when mom had the car because the dealer took care of it. I could well be wrong but I didn't recall seeing it on the oil filler cap like it was on the 2011 Malibu and the 2014 Cruze. With the HR being a 2008 I wasn't sure if it was recommended.
I had never heard of Dexos before we got the Malibu and that was my first new GM car since an S-10 back in 1995.
I just found all of the paperwork and manuals for the car when going through mom's things so I can check the manuals. I also just got the car home late last night and after the funeral etc this weekend maybe I can dig a little deeper into everything.
Thanks
Old 04-17-2015 | 07:38 AM
  #58
db/sb's Avatar
The Dexos specification didn't come into play until the 2011 model year. The spec for 2006-2010 was GM6094M for the 2.2 and 2.4, which was regular, non synthetic dyno oil. When the SS came out in 2008 the spec for it was GM4718M, which is synthetic. In 2011 the spec for all models became Dexos. Some of the brands that meet the Dexos spec are blends rather than full synthetic. The are an icredible number of oils that meet the spec.:
Oils that meet DEXOS spec
Old 04-17-2015 | 07:40 AM
  #59
GM updated their recs a few years ago, now Dexos for oil and DexronVI for ALL.
Old 04-17-2015 | 07:56 AM
  #60
db/sb's Avatar
2.2 and 2.4 with auto trans have been Dexron VI since the beginning. It's the manual trans and the SS that has differening specs over the years until they all went to Dexron VI in 2011.
Quick Reply: Is it safe to switch to full synthetic with high mileage?
