Serpentine belt replace
My 2006 HHR has 101000 miles and so I decided to replace the serpentine belt.
The clearance between the tensioner and the frame is so tight I had to grind a 3/8 drive breaker bar down to a low profile tool.
I would like to thank db/sb for the serpentine tool idea with the hook on the end, it made it easy for a one man job.
But, now that I actually tried the "loaner", I find that it does not work! At least in my case the square 3/8 adapter needs to be on an angle, not square to the shaft. Or, have a second small shaft with a 3/8 square on it. The 1 I got had an extension with a female 3/8 and a male 1/2. The correct tool would have a long handle with a 3/8 male and a short adapter with a "star"(adjustable angle) 3/8 female on one end and a 3/8 male on the other.
