Sunroof adjustments
Old 08-25-2020 | 09:30 PM
JOHNNYO's Avatar
Sunroof adjustments
Hi is there any way to andust the sunroof to pull down tighter into the roof line? Tried cleaning the track and silicone on the rubber and roof contact points. It bettet but still need to push down on the front to seal. Thanks
Old 08-26-2020 | 08:41 AM
A quick search resulted in these articles from the archives, have a read
https://www.google.ca/search?q=hhr+s...iw=375&bih=626
Old 08-26-2020 | 08:48 AM
You might try this from the how-to library (where you originally posted this query).https://www.chevyhhr.net/forums/how-...overage-11629/
Old 11-16-2022 | 12:19 PM
WilliamKirkland's Avatar
My HHR to shop for 2nd heater motor resistor. Shop not buying GM parts from dealer, and I've had several returns like 2 fuel pumps for my Mazda pu. I had a broken 2006 driver's side Sunroof closing arm for close to 2 years. My bodyman took a GM part F Bracket #20794829 $5.53 on line from GMPartsnow, drilled out the 06 bracket, filings into headliner? who cares at 16 yr old car..had to manupulate the screwed in bracket to get the slide to work but he's strong and has tools to slightly improve parts, Worked 4 times, closed never to reopen again! Never own a sunroof car. Trouble about to happen.
ChevyM84
06-18-2017 11:13 PM
Jpak88
Mods - Exterior
06-12-2017 08:56 PM
AJL08SS
06-16-2014 11:18 AM
Tyler Harvey
Maintenance and Upkeep
10
06-30-2011 10:19 AM
pjtaxi
01-13-2006 10:03 PM
