Transmission fluid change
Old 05-23-2022, 04:20 PM
  #31
ScareDe2's Avatar
I want to be extra careful. This plug hole can't be blocked by worn particles ? Should I double verify it's opened with a screwdriver or something first?
ScareDe2 is offline
Old 05-23-2022, 04:27 PM
  #32
You could but I doubt that’s the case. Careful now , if you shut off the engine the fluid level will rise!
Oldblue is offline
Old 05-23-2022, 04:43 PM
  #33
No offense meant but is this where you are pouring in the new fluid ?
firemangeorge is online now
Old 05-23-2022, 06:32 PM
  #34
ScareDe2's Avatar
I think so. It's where the black filler cap is. Watched all the youtube videos and they all shown the same.
ScareDe2 is offline
Old 05-24-2022, 08:41 AM
  #35
ScareDe2's Avatar
I added the last 250ml I had, No drops. Maybe I am doing something wrong. A full 1L had been added by me.
ScareDe2 is offline
Old 05-24-2022, 08:59 AM
  #36
Here is another view of the check plug: Looking from passenger side.
donbrew is offline
Old 05-24-2022, 09:16 AM
  #37
For reference, in the video I posted above, you can see the engine oil drain plug just to the right of the transmission level plug. Pretty much the same perspective as the drawing that donbrew just posted.
Please confirm that this is how you are doing this.
RJ_RS_SS_350 is offline
Old 05-24-2022, 09:41 AM
  #38
ScareDe2's Avatar
Yes... it is the transmission check plug, 11mm torqued to 9 foot pound. Close to the oil drain plug. I can't see what else that could be.
But wait a minute, I am gonna try to take picture. Who knows :
The little moisturized spots you see I did it with my own fingers when I unscrewed or screwed back the plug. It is not drops from the transmission pan. As you can see the area is still completely dried.
ScareDe2 is offline
Old 05-24-2022, 10:13 AM
  #39
ScareDe2's Avatar
Another video here :
ScareDe2 is offline
Old 05-24-2022, 11:33 AM
  #40
Trust issues or not; I would have to go back. You paid for product and service you didn't get. DexVI is not cheap. They should not have just added the amount the book says, that is why there is a level control port. It should be checked at over 104F and running to account for expansion.
Should be a steady drip.
donbrew is offline
Quick Reply: Transmission fluid change
