turn signal switch replacement
Old 08-30-2018 | 08:30 AM
Cliffs51's Avatar
I searched for an answer to this but didnt see anything but I apologize if I missed it. My 07 turn signal cancel hasnt worked since I bought the car in June. I ordered a replacement switch off ebay and when I installed it I could not quite get the clips to click into place and it did not cancel like its supposed to. Does the steering wheel have to be in a certain position for the switch to click into place?
​​​​​​​Thank you in advance for any help
Old 08-30-2018 | 09:02 AM
All the book says is "take it out, put the new one back in, ensure the locking tabs are snapped into place"
Old 08-30-2018 | 09:36 AM
Cliffs51's Avatar
​​​​​​​Ok thanks Don. I suspect its the $18 Chinese part that is the problem. Going to get a refund and buy an oem part.
Old 08-30-2018 | 10:13 AM
aradmahogany's Avatar
Hell, mine stopped working only on a certain right hand turn during my commute. Not bothered with fixing it lol.
Old 08-30-2018 | 10:42 AM
Cliffs51's Avatar
Too funny. It bugs my wife when she drives it thats the main reason im trying to fix it.
Old 08-30-2018 | 11:16 AM
I would suspect a wire out of place or a burr on the plastic.
Old 08-30-2018 | 11:43 AM
Cat Man HHR's Avatar
Same thing with me when I bought outside door handles (Junk). Returned them and contacted hellshotrod on this forum for good used OEM parts. Might be the way to go.
Old 08-30-2018 | 12:27 PM
hellshotrod's Avatar
i have good orig parts if u need them i also fix the spring so the cancel ,the little spring warps so u flip it over and they work again till the spring losses its bend
Old 08-30-2018 | 12:51 PM
hellshotrod
Send the member a PM, he or she might not look at this forum much.
By the way your a true person when buying parts from you.
Richie
Old 08-30-2018 | 07:31 PM
Cliffs51's Avatar
Thanks everyone for your help. I may try the fix on the existing switch. Special thanks to Dave who has been really helpful. I notice that on the new switch the little white plastic tab that acts as the trigger barely sticks out at all. How much is it supposrd to stick out?
