Window not working
Window not working
UPDATED Thread #32 THANK YOU Everyone
They found a Broken wire under the seat
2011 HHR 2.4 2LT
My sons HHR
Came to visit w/his dog and she hit switch, rear passenger side and opened window, Now will not close
He did have a issue sometime closing the rear drivers side off the Master!
Picked up a Dorman master switch and none of the windows work! Bad New Switch ?
The widow lock light does come on ,so assume have power !
Checked fuse 29 30A and I get continuity
Is there another fuse somewhere else ?
Used a Fuse box diagram off the net.. Fuse box on passenger side
Thanks
2011 HHR 2.4 2LT
My sons HHR
Thanks
Pssst , RJ , we’re on the internet! But your right about the fuses.
Rich did you try cleaning the OEM switches?
https://www.chevyhhr.net/forums/how-...ontacts-62119/
Is there only 1 power source to the master switch or 2 ?
I ask because when you hit the window lock button the light comes on . !
My son will check the fuse's tomorrow, Temps will be warmer 35* instead of 15* :)
Two fuses , two power sources, seems logical. However the power windows fuses are
#17 window RAP
#29 power windows
those are in the interior fuse panelhttps://fuse-box.info/chevrolet/chev...uses-and-relay
#36 under the hood is a power windows fuse but only for the SS turbo’s
#17 window RAP
#29 power windows
THANKS again will see what tomorrow brings !
My son will try the old switch today, It did have 3 windows working , And if they work the new switch is NG. Either way he will go to the Parts store and grab some fuses for his kit !
