Yay or Nay? Change Transmission Fluid?
267,000 miles, still has original transmission fluid. Would like to change it (drain and fill) but kind of hesitant after this long. Transmission works fine, very rarely I'll feel a very slight "slip" but not often. Fluid level is currently good and old fluid still looks surprisingly good. Still red and still pretty clear. What do y'all think?
Technically, the fluid is "lifetime" unless you use the car for livery.
Change it with Dexron VI if you want to. Early 2006 models came with Dexron III but GM upgraded the recommendation.
Don't flush & fill at that mileage.
Profile says 2008, so Dextron VI
Here is a how to
https://www.chevyhhr.net/forums/how-...-change-58325/
Here is a how to
aradmahogany
Maintenance and Upkeep
07-27-2015 08:06 PM
