Engine Lite is on
Old 11-11-2006 | 03:16 PM
Z-Man's Avatar
Thanks I feel much better and it has not come on since this morning.
Thanks Michael and everyone else.
Old 11-16-2006 | 06:59 AM
Black Beauty's Avatar
What ???
Originally Posted by Z-Man
Michael
Thanks I took it to Auto Zone and they cleared the light & they said the code was the coolant wasn't hot enough. He said if it comes on again take it in to the Dealership since its still under warranty. Thanks again. I did not know that Auto Zone scans for free or that they even do that stuff.
Thank you
The coolants not hot enough ? Did you say Auto Zone or "twilight zone" ?
Better take it to the dealer, could be the thermostat. If you have heat, the coolant is hot. How can the coolant not be hot in a running engine ???
Old 11-16-2006 | 07:05 AM
solman98's Avatar
I was thinkning the same. If the "coolant not hot enough" triggered a CEL, then it would come on every day when you started it up.
Fluid low, yes. Not hot enough? Strange.
Old 11-16-2006 | 07:47 AM
Z-Man's Avatar
I took it to the Dealership on Wednesday morning and they said the same thing that Auto Zone said, It's the Thermostat and they have to order the part, No one in the Chicago Land area has one due to the HHr being so new. I will have to take it back on Friday to replace the Thermostat. I have fond out that by the Thermostat being bad effects alot of reads outs on the dash computer system. Its says COOLANT -------F, Temp read out is off , and other reading are out also. I will inform you all on Friday night, wish me luck!
Old 11-16-2006 | 07:56 AM
solman98's Avatar
Sounds like it stuck open at least.
Old 11-16-2006 | 11:20 AM
-md- HHR's Avatar
Stuck open is ok, stuck close now that would be bad.
Old 11-17-2006 | 06:11 PM
Z-Man's Avatar
Okay here is what they did as per the paper work. My son took it in for repairs. CHECK ENGINE LIGHT, TEMP GAGE INOP AND NO COOLANT TEMP READING CAUSE: INOP (1) 90537453 THERMOSTA (1) 12346290 COOLANT
FC: 1H, PART# 9053743, and now the Dang HHr is now repaired.
All they did was put in a new thermostat and reset the computer. per say.
Z
Old 11-17-2006 | 10:39 PM
dhickey's Avatar
Thanks for the update Z-man....
Don
Old 11-18-2006 | 07:42 PM
Z-Man's Avatar
No problem Don
I am just happy that is wasn't a big thing.
andyb
7
06-09-2015 11:58 PM
leopardcurman
08-24-2014 12:54 AM
J.Lo
07-11-2014 06:43 PM
11matt77
01-05-2014 01:01 PM
dixiesHHR
08-30-2007 02:48 PM
