Began Mocking Up Windshield Visor
Has anyone had any luck finding a visor other than the single sheet rolled metal one or the 1970's looking boxy one? I haven't, so I have started mocking up a windshield visor because I could only find those two still on the market. I can't say I am crazy about either of them. Not to say the two are bad...just not the look I am going for. Once I get the mock-up done I will make a solid prototype to install and begin testing. I will update as the project progresses.
This one was made several years ago, hasnt been made for several years as the custom shop that made them went belly up.
Took me a couple years to locate the 2 that I have and I actively searched for them.
SSFan got a LUND visor with the Black Panel he recently bought. LUND hasnt made them for the HHR for several years now either.
The one I have for the '55 Chevy Bel Air 2 door hardtop is stamped steel with a stainless steel trim edging.
sleeper,
I completely agree...American and Proud does have the cool one! Off the top of my head, I don't recall the plexiglass one...I'll have to check those out on Google.
American and Proud,
Do your vents you have an air release on the trailing edge, or are they attached at the roof line as well as the sides (pillars)?
American and Proud,
sleeper,
American and Proud,
American and Proud,
I believe they are made of black abs sheets. My guess would be that the ABS is heated and then vacuum formed over a mold. the same with the center mount, then its abs glued to the underside of the visor.
American and Proud,
Thanks, I was curious because of air flow. With the design I am working on I am going to mount it with the 3M two-sided tape. It will have attachment points on both the windshield and roof with air release channels. I am shooting for a look that hugs the windshield fairly close.
I would not want to rely solely on the 3M tape as a way to attach it to the car. The forces on the visor, even with the air release channels, is going to be very substantial at highway speeds.
American & Proud: your thoughts on this?
whopper,
The amount of surface area that will have contact with the the 3M tape is very substantial. There are cars that com from the factory with body cladding that is adhered with this tape. I do appreciate your input and I have planned from the begining on proceeding with extreme caution and testing the visor extensively before putting finish paint on it in case of failure. I hope to be able to mount it without drilling holes into the A-pillars, but I do have a contingency plan (that includes fasteners) if need be for my design plans.
Thanks again for your feedback...I will be posting some pics up soon :)
