? drill holes or 3m on...
So i got my hood scoop back white & black and now i have to decide, do i just 3m it down like it says, or use the two front speed screw's also added with the hood it's very light weight and optional but included for very hot areas where the tape could soften after time.
your thoughts...
jeff
your thoughts...
jeff
Might help posting some Pics.
How can we make any suggestions without a clue what were advising you on?
Large scoop, small, large or small front opening, anyway for air to pass on through/past?
Pics of the screws, maybe a word for word of the Directions?
Just Trying to Help.
So they probably give you the screws so you don't end up chasing it down after it's blown off on the 405 freeway .....
Heck we say why your at it make it functional and get alot of cold air to that sucker ..... Drill, Sawzall, Holesaws .....
Best-O-Luck .....
Best-O-Luck .....
I put a whole bead of 3m on mine , And it has never moved.
I've taken it off a couple times for a repaint of the scoop, The only way to get it off is razor blading threw the thin 3m foam , Because your not gonna just pull it off .
