? drill holes or 3m on...
Old 03-24-2012, 02:03 AM
jeff schaffer's Avatar
So i got my hood scoop back white & black and now i have to decide, do i just 3m it down like it says, or use the two front speed screw's also added with the hood it's very light weight and optional but included for very hot areas where the tape could soften after time.
your thoughts...
jeff
jeff schaffer is offline
Old 03-24-2012, 05:14 AM
Rest In Peace
American & Proud's Avatar
Might help posting some Pics.
How can we make any suggestions without a clue what were advising you on?
Large scoop, small, large or small front opening, anyway for air to pass on through/past?
Pics of the screws, maybe a word for word of the Directions?
Just Trying to Help.
American & Proud is offline
Old 03-24-2012, 05:45 AM
BlackknighT's Avatar
No Holes. You might regret it later.
BlackknighT is offline
Old 03-24-2012, 06:26 AM
Mrs. DLVRNIT's Avatar
So they probably give you the screws so you don't end up chasing it down after it's blown off on the 405 freeway .....
Heck we say why your at it make it functional and get alot of cold air to that sucker ..... Drill, Sawzall, Holesaws .....
Best-O-Luck .....
Mrs. DLVRNIT is offline
Old 03-24-2012, 06:28 AM
Oh and would a Flute with "No" holes be a Stick or a Whistle ......
Best-O-Luck ,
Old 03-24-2012, 06:43 AM
Haunted_Hot_Rod's Avatar
To further that... is a flute that never is played a stick or a whistle?
I thing is not until it has purpose.
Haunted_Hot_Rod is offline
Old 03-24-2012, 09:29 AM
THE BATMAN's Avatar
I put a whole bead of 3m on mine , And it has never moved.
I've taken it off a couple times for a repaint of the scoop, The only way to get it off is razor blading threw the thin 3m foam , Because your not gonna just pull it off .
THE BATMAN is offline
Old 03-24-2012, 12:51 PM
frank6060's Avatar
If applied properly it aint going nowhere with 3M tape...
frank6060 is offline
Old 03-24-2012, 09:18 PM
Thanks...
thanks... pics soon
just thought it would be safer thats all.
jeff
Old 03-25-2012, 12:08 AM
tease
SS fan is offline
Quick Reply: ? drill holes or 3m on...
