Dupli-Color tint spray question.....
Can someone link me to the duplicolor tint spray and mayhaps advise
Me how much I will need for front grille door handles all four and rear beauty bar?
Moved your question over to the "Appearance" area Kev, so it doesn't get lost or overlooked.
I'd say that you should probably buy two cans of the tint spray, you may only need one can, but buy two just in case. If you don't need the second can, you can always return it.
Doc fixed you up with some good links for info.
Found out long ago.......
When doing ANY kind of new work, construction remodel, auto repair, landscaping, etc. buy more than you think you need and return the unused when the job is complete.
This will prevent running for a last minute part, material, etc. when you calculate short.
JMO
JMO
If your buying the Duplicolor Shadow kit you will only need 1 kit. I just did mine along with the lower billet piece and even with 4 coats I still have at least half of everything. The door handles and the beauty bar won't take a lot.
