Dupli-Color tint spray question.....
Old 06-16-2012, 09:49 AM
LawDog88's Avatar
Can someone link me to the duplicolor tint spray and mayhaps advise
Me how much I will need for front grille door handles all four and rear beauty bar?
LawDog88 is offline
Old 06-16-2012, 09:52 AM
Haunted_Hot_Rod's Avatar
>>>Duplicolor<<<
>>>Duplicolor Tint Spray<<<
Haunted_Hot_Rod is offline
Old 06-16-2012, 10:02 AM
Moved your question over to the "Appearance" area Kev, so it doesn't get lost or overlooked.
I'd say that you should probably buy two cans of the tint spray, you may only need one can, but buy two just in case. If you don't need the second can, you can always return it.
Doc fixed you up with some good links for info.
843de is offline
Old 06-16-2012, 12:48 PM
Snoopy's Avatar
Found out long ago.......
When doing ANY kind of new work, construction remodel, auto repair, landscaping, etc. buy more than you think you need and return the unused when the job is complete.
This will prevent running for a last minute part, material, etc. when you calculate short.
JMO
Snoopy is offline
Old 06-16-2012, 01:15 PM
LawDog88's Avatar
Thanks Snoopy.
LawDog88 is offline
Old 06-16-2012, 01:16 PM
LawDog88's Avatar
And thanks to the rest of you too. :)
LawDog88 is offline
Old 06-16-2012, 06:26 PM
solman98's Avatar
If your buying the Duplicolor Shadow kit you will only need 1 kit. I just did mine along with the lower billet piece and even with 4 coats I still have at least half of everything. The door handles and the beauty bar won't take a lot.
solman98 is offline
Old 06-16-2012, 06:28 PM
LawDog88's Avatar
Thanks Solman
LawDog88 is offline
Old 06-16-2012, 07:24 PM
LawDog88's Avatar
Solman what did you use for "prep"??
LawDog88 is offline
Old 06-17-2012, 08:03 AM
solman98's Avatar
Since what I was spraying was brand new, I didn't have to worry about any oil or wax on it. BUt duplicolor has a prep you can use.
solman98 is offline
Quick Reply: Dupli-Color tint spray question.....
