foglights
Old 03-23-2011, 07:22 PM
capp002's Avatar
foglights
has anyone had any luck or used thesehttp://cgi.ebay.com/ebaymotors/06-09...Q5fAccessories
capp002 is offline
Old 03-23-2011, 08:40 PM
Lucky's Avatar
Looks like an easy hook up. not a bad idea.
Lucky is offline
Old 03-23-2011, 08:53 PM
gottahaveheart's Avatar
fog light switch
Has anyone here had any experience with bypassing the factory fog light switch, as to have the fog lights on at all times the car is running??
gottahaveheart is offline
Old 03-23-2011, 09:11 PM
capp002's Avatar
foglights
im tryin to find out if its worth buyin and to see if it can be wired to come on when the lights do
capp002 is offline
Old 03-24-2011, 09:25 AM
B1GP1MP1N's Avatar
I would be curious about how 'Plug and Play' these really are.
B1GP1MP1N is offline
Old 03-24-2011, 10:21 AM
solman98's Avatar
Can't see the pics on the link for whatever reason, but how can a single plug and play fog light fit the standard HHR and the SS?
solman98 is offline
Old 03-24-2011, 10:25 AM
Gotta read the fine print in the body of the add.
"Chevrolet HHR 2006 - 2009 (all models, 08 & 09 - except SS models)"
843de is offline
Old 03-24-2011, 10:38 AM
Putter's Avatar
I just tapped into the hot wire of my side marker and used that voltage to trigger a relay. Doing this turns my fogs on any time my park lights are lit (park only, high beam, and low beam).
I don't have a factory switch. Lights did not come installed from factory.
Putter is offline
Old 03-24-2011, 10:53 AM
solman98's Avatar
Well, that may be true, but he also lists:
2008 Chevrolet HHR LS Panel Wagon 4-Door 2.2L 2198CC 134Cu. In. l4 GAS DOHC Naturally Aspirated
2008 Chevrolet HHR LS Wagon 4-Door 2.2L 2198CC 134Cu. In. l4 GAS DOHC Naturally Aspirated
2008 Chevrolet HHR LT Panel Wagon 4-Door 2.2L 2198CC 134Cu. In. l4 GAS DOHC Naturally Aspirated
2008 Chevrolet HHR LT Panel Wagon 4-Door 2.4L 145Cu. In. l4 GAS DOHC Naturally Aspirated
2008 Chevrolet HHR LT Wagon 4-Door 2.2L 2198CC 134Cu. In. l4 GAS DOHC Naturally Aspirated
2008 Chevrolet HHR LT Wagon 4-Door 2.4L 145Cu. In. l4 GAS DOHC Naturally Aspirated
2008 Chevrolet HHR SS Wagon 4-Door 2.0L 1998CC 122Cu. In. l4 GAS DOHC Turbocharged
2007 Chevrolet HHR LS Wagon 4-Door 2.2L 2198CC 134Cu. In. l4 GAS DOHC Naturally Aspirated
2007 Chevrolet HHR LT Wagon 4-Door 2.2L 2198CC 134Cu. In. l4 GAS DOHC Naturally Aspirated
2007 Chevrolet HHR LT Wagon 4-Door 2.4L 145Cu. In. l4 GAS DOHC Naturally Aspirated
2006 Chevrolet HHR LS Wagon 4-Door 2.2L 2189CC 134Cu. In. l4 GAS DOHC Naturally Aspirated
2006 Chevrolet HHR LT Wagon 4-Door 2.2L 2189CC 134Cu. In. l4 GAS DOHC Naturally Aspirated
2006 Chevrolet HHR LT Wagon 4-Door 2.4L 145Cu. In. l4 GAS DOHC Naturally Aspirated
For that reason alone, I would not trust this seller. Get it right the first time.
solman98 is offline
Old 03-24-2011, 01:26 PM
nacademus's Avatar
If you're going with HIDs... just get the fogs for $80 Shipped and make your own harness with relay.
nacademus is offline
Quick Reply: foglights
