HELP!! Fugly pinstripe
I hate when ugly pinstripes sneak up on you...
If its not cleared in, which it appears to be a sticker anyways, you can take a heatgun to it and gently peel it off. If its cleared, you willneed to sand it down a bit, peel it off, then buff it with rubbing compound to match the surrounding.
Looks like a one piece printed decal. Probably 2mil 3M vinyl. Like TK said, "Wait for some sunshine and a warm day. Get one edge started and They should lift off easily, just go slow and steady.". Or you could use a hair dryer on low heat. Just don't hold it to close.
I suggest the hair dryer and a plastic razor blade if you can get some. Or if you use your fingernail you may be able to get a corner up and start pulling. But it's going to take some time that way. the plastic razor blade is probably the best way. Just be careful not to push too hard on the paint as it can definitely still scratch a little bit with the plastic razor blade.
